feathering in
smurfy
to prevent seeing the shadow outline of patching boarded up doorways etc I've been taking the plaster well beyond the edge and feathering in. This works great but when painting the plaster the feathered edge of plaster has been peeling off with the paint. I imagine this is because I've gone past the unibond. Does this make sense?
If this is correct then I guess I should unibond further but this will give me an area of wall that is unibonded but not plastered over and then this will affect the paint. What to do?
Hope this makes sense.
The Pva won't affect the paint. Even if it did the decorator would just need to rub with fun sand paper to key up.
Exactly. Just pva a bit more than you think you'll plaster to and blend in.
If it peels it's the decorators job ;)
It's were your using fat to feather in that comes away when painting, fat returns to dust and do's not stick
