fastest way to do patches
go one night and bond it. Then when you're next free in 18months time itll be that dry the skim will dry in seconds
same as that bonding and skim mixed together and some times a small hand full of cement,, goes of like a bullet ,,
round 30% bonding and the rest skim,, just a little cement tho as it will go off fast,, use to use this method when patching up after window installation's,,
I like your style. Rather than try to work out how to do more than 10m2 a set youre going to do 6 10m2 hits a day lol
Use some skimming out of a half open bag which is about 6 months past the use by date!
Mix it up then it's like countdown to get it in the patch! Will be set in 30 seconds
I good tip is keep a couple of bags to the side and let them go out of date, then just bonding and skim as normal but sets in seconds lol
Handfull of finish in the bonding works for me.. Used tile adhesive to fill one once took hours to go off lol
I just fill the chase with multi, it dries, shrinks and starts to crack after 10 mins. Then just 'lay it in' like u normally would and trowel up straight away. Jobs a good 'un :RpS_thumbup:
