Expansion Beads
Arti
Got to thincoat a big gable and I'm using expansion Beads to split it up just wondering if the render lads just over coat the expansion bead so it's all the same colour or mask it up so the bead colour is kept?
Was just gonna spray over them so it's all the same colour
Divvent nah if this is a bone question or not........f**k nahs
Anyway thanks in advance for your value opinions
Love
Arti
Xxxxxx
Wouldn’t bother with expansions unless you want to give yourself a break?
If so just clean them off before you go..
If you get proper expansions (not just back to back stops) they come pre taped in the gap [emoji106]
As Spanky said, the good ones come with cling film over them.
Did a gable this morning 75m2 in Silicone. Arms are knackered, beads from now on. Split it into 3.
As above. I’ll just add that the film is not strong enough to pull the weight of full joint with render so clean it as you go and as much as you can before you pull the protective film.
