No it's not sticky. Joint filler is best for applying paper tape but skim will work. Wet the tape first and let it rest few a mins before using.Is paper tape sticky or do you put It on with skim It' not bad pattern but builders f**k*d em over . She thought she was having it boarded.
No it's not sticky you just stick it up with whichever finish plaster you're using. You don't need to pre-wet drywall tape.Is paper tape sticky or do you put It on with skim It' not bad pattern but builders f**k*d em over . She thought she was having it boarded.
I'd imagine that he wants to use paper tape as it's more crack resistant than scrim.why are you using paper tape... use scrim
Customer says ceiling was to be boarded builder says not . Bad cracks so gone for paper . Stuck it with skim then gone over with scrim as well . Fell sorry for customer 53 year old ex model from South America @Marshy would pay for this job ultimate milfI'd imagine that he wants to use paper tape as it's more crack resistant than scrim.
Pictures or never happenedCustomer says ceiling was to be boarded builder says not . Bad cracks so gone for paper . Stuck it with skim then gone over with scrim as well . Fell sorry for customer 53 year old ex model from South America @Marshy would pay for this job ultimate milf
Aren't we all happily married? Selfie with her sounds reasonableI.m happy married . See what I can do but not sure if I can pull the . Do you mind me taking a selfie so loads of plasterers can perv on internet over you .
I Only pre wet when using plaster. It's got a habit on shrinking on the tape.No it's not sticky you just stick it up with whichever finish plaster you're using. You don't need to pre-wet drywall tape.
I put them on using a banjo, so obviously dry.I Only pre wet when using plaster. It's got a habit on shrinking on the tape.
I did mate.May a bit late, but I’d be finding the joists and rescrewing the boards up as well.
I did mate.
Got me mate in to paint it lol . Nightmare it was that wavy ceiling . Lines which ever way I trowels . Found out of customer builders made 700 on top of us .rob dogs but what can you do if they keep ye busy .Thank f**k the emergency is over
It's the "builders" problem now.....painter will fix it
How much for stair caseI'd not if ffs
Why are you tagging them, they know less than anyone about finish plaster?
Just the milf would doHow much for stair case
