Ecorend mr1
Willapp24
Hello I've got a wall 900mm high basically I've primed it using the s10 a few days ago
Now I'm putting it on by hand as its only about 5m long am I right in putting first coat on around 7mm using straight edge when nearly gone off and using serrated edge to get air out and float back flat then leave it for the day and do the second coat around 10mm the next day early on and same procedure but use a scratch float to do the finish?
Help would be appreciated
