Easifill on inside of external wall
Peter_
Hi all,
Just bought a house and had it rewired, leaving lots of chases to fill. All new to me, but the electrician recommended Easifill 60. Done a few and worked well, but I came across something warning against using Easifill on external walls, but can't seem to find it again.
Is there any increased risk of attracting damp with Easifill? Should I use something else on the external walls, if so what?
If your house has no cavity and is single skin then you made need to review it if not crack on but easifill is only for a thincoat you can't lob it over brick
Great, there is a cavity, so sounds good. There are a few points where I'm going to need something more serious, but mostly I think it will do the job.
Thanks so much.
Be wall papering every room then I take it!!
Should of just had the house skimmed!
You get out when you sell what you put in!!!
Iv used it before filling chases out works well even upto 30mm
Ye used in the other day after new sockets installed at home...used the 60 version and it's was still unsandable the following day at about 10mm...although it was cold in the room
