Easifill 60 or 20
windy
Got a bit of filling to do on a job. Is there noticeable difference between standard easifill and the 60 and 20 versions???
Used the 20minute stuff before in winter and still wasn’t ready to rub down 7hours later was about 3degrees lmao
They set solid in the times stated but you can't sand it down until the next day, so can't really ever see the point in using the easifill 20 unless it's a tiny job and you wanted to second coat it quickly
Nice one. Thought the 20 one would be sand able within the hour ...
I used 20 on Saturday with dirty water. Filled a patch and was solid in 3 minutes. Mixed up a second mix and smoothed over and was perfect. No need for sanding. Easy money
Find you always need to overfill slightly and sand. Try and get it dead smooth and it just bubbles
