dura finish high impact finish
You need to get it in to shape asap as it pulls in quick and once its pulled in you ant gonna be changing its shape
Do you bang a wall on, drop back and flatten it then put another on ........
Yer its picks up alot in the first 15mins, so if your using the tools we do you dont wanna let it sit on the way hardly any time before making sure its flatten, other wise you dont get rid of the laying on ridges and i looks wank
Both spray and dura work best at 2mm. If the frames are to chunky you should be getting extra to sort them out.
First coat,it wait have cuppa or whatever ,second coat then keep troweling you can end up with a good finish with Dura when you get to tweek it,
