Dri-Coat
chris16
Any one had much experience with this stuff, looks straight forward enough, just heard it can be bit of a bugger to rule off
Easy to use and use it over damp work. It's not always about S & C, renderlite
Used this stuff quite alot, mainly on external walls that are damp, works a treat, but it is proberly the worst stuff in the world to mix as its like limelite and it gets down you throat and would definatly recomend a dust mask. As for ruling off depends on the background. I found if its brick work (which i usually is on damp) pva it and it rules off with out taring. Hope this helps :)
