downlighters flush fit
I fitted some of these for a customer a couple of years ago the best way is get some easy fill around them then sand the easy fill down flush with the light.
Easi fill, DIY section, most we have skimmed over have a polystyrene cap which you pop out after the last trowel ,the often cause you to put a heavier coat on than normal ,possibly upto five mm ,speed skim is handy on these ceilings ,the flatter the ceiling is the better,
yer i went to look yesterday where the electrician had fitted them the holes were about 2 the size needed to be
and they sat proud of the plasterboard
