domestic spreads/sparks
algeeman
It’s A Boy
where does that cable go
loop or way ??
forgot to take picture of the light switch.
cheers mudafuckers (y) (y)
Result. Feed in, feed out, one will always go in the common and the other in '1 way' as its just a basic switch. Get them the wrong way round and switch will be on when off etc. Swap around or turn switch upside down if you cant be arsed :rayos:
that's all sparks do
take pics of each others work and copy it...
I forgot to take the picture :rayos:
If you joined those 2 reds together then light will stay on. The switch is just a breaker so you can't go wrong. it's wired correct and earth connects to back box.
Dispite reds and browns. Blues and Blacks in switches they are all live wires. No neutrals. Simple live in as and live out and switch acts as a breaker.
Not all are permenatly live, 1 is and the other is a switched live, which is only live when switched, hence the name.
