Damp Proofing
B
bigsegs
Guest
Now then....I read that people seem to be uncertain as to which undercoat to use ref. damp proofing / flood damage..
I used to work for a dp company, most of it was hack off metre high, render and skim
Company that supplies the chemicals and additives will not under ANY CIRCUMSTANCES guarantee a job that HASN'T been rendered back up with a 3:1 sharp/plastering sand:eek:pc mix with integral waterproofer/salt repellant..
Theory goes a bit like "Bonding is porous" end of :eek:
they reckon it'll just soak the water straight out of the wall bringing the salts with it, thereby i suppose causing the installation company and chemical supplier grief from customer,,
company i worked for wouldnt advocate bonding/hardwall or silmilar downstairs in old properties anyway, damp or not..always render..
Still that said it was 50% building company too so trailer/mixer/groundsheet was never a problem...
Cant quite understand why people hate good old fashioned render anyway? I dont mind it at all, in fact i get on better with it than bonding (which i only ever use to patch up/caulk out with)?
Another good thing about rendering with waterproofer -
1) itll hold it off so you can throw tons of it on before you have to float up
2) if youve used the right ratio of waterproofer (bout 1/2 litre to a mixerfull) youll never have to pva the walls before you skim, in fact you can pretty much bang the whole room on in a set...or three rooms if your only a metre high..
noticed this 'limelite' been mentioned though....never heard of it?? any good?
p.s. anyone that ever rendered after a chemical injection and cant get render to stick...the gits have sprayed chemical up the wall...might as well try and render glass walls...not funny :'(
the spraying the walls is one thing that really gets my goat :mad:cant stand render myself as have been using limelite renovating for the last 20 years
Just gone for a look for limelite...
Is this right...28+quid per BAG!
ok i assume thats list price etc but bloody hell i can get a TON of sand for that
read the spec tho...breathes while still holding back the salt, waterproof barrier while still remaining porous :eek:
found this for renderlite..
Form Supplied: Powder
Pack Sizes: 25 kg
Colour range: Grey
Contains: Cement, lime, aggregate and waterproofing additives
30 quid a bag
I cant see the difference bar the lime?
would you knock it up in a cement mixer same way you would normal render??
I ask this cos when ive done old houses before i tend to find im throwing render on up to 3-4 inches thick in some places and i can put it on the wall as fast as the labourer can mix it and get it to me in a barrow, some of these old properties suck like ...well u know..
used the limelight stuff while ago on old cottage walls, this stuff is crap, the finishing plaster is hard to get a good finish on, anyone else have this problem?
thats only for old cottage walls though? and yes very exspensive.
yeah it is hard to get a good polish sometimes,sometimes better giving it a dry scuff the next day,i get my limelite at jewson for £10.85 plus vat(which i get back)ive mates that work there ;)
Pack Sizes: 25 kg
Colour range: Grey
30 quid a  bag
i just get the laddie to mix it in the bath,youve really got to know the nature of the stuff and know what liberties to take with it
