Cutting concrete
ncowan
Ok, I will be floor-mounting my new G70. The problem is, the floor in my theater is concrete and I don't have the ceiling height to construct a raised floor.
So that I can hide the cables, I want to run PVC tubing on the concrete floor.
So... How do I go about cutting a 12' long 3" wide 3" deep channel in the concrete floor? Is there any way I can accomplish this
without using a water-cooled diamond-tipped blade? Once I get the channel cut and pvc installed, what type of cement should I
use to fill in the gaps?
concrete resurfacing atlanta
thanks in advance for any help
Without a diamond tip blade you're gonna struggle to get it done neatly ?
Unless you've got an industrial lazer cutter maybe.
Or acid to scrape layers over a long period ?
Thunk out of the box there, but gonna need a bigger box ? :coffe:
Concrete cutter.
That's what you need
I'm working on the principal that it's kinder on everyone if we put him down. Be sad for a day or two, but we'll bounce back. Maybe we'll even build back better.:eek:
Principle,you illiterate mong.
PRINCIPLE.
  • NINGS
  • GAMES
  • LEARN
  • WRITING
  • WORD OF THE DAY
Elementary Level
principal​
[ prin-suh-puhl ]SHOW IPA
See synonyms for principal on Thesaurus.com
adjective
first or highest in rank, importance, value, etc.; chief; foremost:The principal problem is a lack of money.She's the principal advisor on the council.
So you're asking plasterers about cutting concrete? Duh?
What have you got against the proper way, using a rental wet blade concrete cutter? any way you do it there will be mess, fact of life.
Or you could do what I did to cut a garden path - 12" disc hand disc cutter, lots of noise, dust and time (use mask, ear protection and safety glasses).
You either make several 12' lengthwise cuts 3" deep then smassh it with a sledge hammer and chisels, or cut a big deep V with a little space at the bottom for cable - then smash it with the aforementioned sledgehammer.
And you back fill the hole with more proper concrete not some poofy mortar that will crack and fail quite quickly.
Thespians huh?
Thespians huh?
Sunny Sundays are meant for drinking :coffe:
youl need diamond cutter disc
without using a diamond cutter disc
youl need a diamond cutting disc
