not used anymore mate ,used to use one lime plastering ,use them the same as poly floats to flatten plaster ,finish is a "scrubbed " or "scoured" surface flat ready to take next coat , need to keep them wet so they dont dry out and crack!
ive used one on lime render but it does leave a very open finish-looks a bit like a scratched back mono-if your using it on lime t=you want to avoiid over working or it will bring a fat to the surface which will weaken the surface of the render
