Best to pull them wooden ones off sometimes but I have in past,also put 4 inch scrim around the wooden bead then bead then 2 inch down both sides 4 good measureAny body had come back from doing bottom meter in sand and cement in to plasterboard even after scrimming joint.
Also on wooden beads. I.ve never had comeback after scrimming bead but kid who's doing job with me next week says he has so wants to pull em of.
Did you solid dab the bottom of the plasterboards and allow a week for SC before skimmingAny body had come back from doing bottom meter in sand and cement in to plasterboard even after scrimming joint.
No didnt know there was damp till today . Fixed a battern to wall so I could board rest of staircase stillDid you solid dab the bottom of the plasterboards and allow a week for SC before skimming
I'd rather have solid dab myself , more consistent thermal jointNo didnt know there was damp till today . Fixed a battern to wall so I could board rest of staircase still
I can make it solid once batterns ofI'd rather have solid dab myself , more consistent thermal joint
I.ve scrimmed loads and never had come backTake the wood out its expanding an contacting it will always crack trust me tried it fckin loads
Your asking a question i always take them out then you can sleep fast a bo bos in bedI.ve scrimmed loads and never had come back
I.ve been back to jobs I.ve done it on and not cracked . Only time I known it to crack was when I never scrimmed emYour customers probably think if you can’t be arsed to do it properly in the first place you aren’t going to come back and rectify.. hence the lack of comebacks
Because some people want straight angles why would you still want a fukin wooden bead stuck out from 1918 Victorian timeswhy not not leave beads on form a v joint down it and do the job right
take it u no respect for a time when things where done rightBecause some people want straight angles why would you still want a fukin wooden bead stuck out from 1918 Victorian times
Always had cracks on wooden beads on chimney breastAny body had come back from doing bottom meter in sand and cement in to plasterboard even after scrimming joint.
Always had cracks on wooden beads on fire breasts when over skimmed, after fixing bead and taping, so always pull them off now, along with a load of plaster...Any body had come back from doing bottom meter in sand and cement in to plasterboard even after scrimming joint.
Actually they are keeping the 20 inch coving and 20 inch skirting so might ask if they want to keep em.Because some people want straight angles why would you still want a fukin wooden bead stuck out from 1918 Victorian times
1918 go back to schoolBecause some people want straight angles why would you still want a fukin wooden bead stuck out from 1918 Victorian times
Did then but its fukin 2020 now u old c**ttake it u no respect for a time when things where done right
Whatever cant be arsed1918 go back to school
HuhActually they are keeping the 20 inch coving and 20 inch skirting so might ask if they want to keep em.
Whats that got to do with if you want a straight beadActually they are keeping the 20 inch coving and 20 inch skirting so might ask if they want to keep em.
no respect for fkall thenDid then but its fukin 2020 now u old c**t
Maybe they would like to keep em. I.vr not asked it's a old property .Whats that got to do with if you want a straight bead
Oh right thought this thread was about putting a skim bead over a wooden s**t beadMaybe they would like to keep em. I.vr not asked it's a old property .
Yeah it is but the job I got coming up I was gonna leave em in but other kid wants to remove em .Oh right thought this thread was about putting a skim bead over a wooden s**t bead
It's big. I ll get some pics when I m there20 inch skirting?
its Victorian john built in 1965Maybe they would like to keep em. I.vr not asked it's a old property .
Whos the other kid an whos the plasterer?Yeah it is but the job I got coming up I was gonna leave em in but other kid wants to remove em .
b*ll***s still crack half the people wont even see there thick as fcukPVA the bead first, bead on, scrim down both sides, bit of bonding on top of scrim then skim it. Never had a bead crack and I always say to the customer if it cracks let me know and I'll pop back and fix it.
Both . I .ve never had a fail he has .Whos the other kid an whos the plasterer?
Spot on, its not like its hard to do. If the wood bead is dooked in to a brick corner and the customer isn't bothered I'll rip them out patch it in and stick skim on and skim it. If its wooden lath then I'll just replicate the original v joint, hate putting skim beads over wooden beads even scrimed.why not not leave beads on form a v joint down it and do the job right
