jord218 said:I use artex to put it up, as soon as the plaster is set. never have any probs.![]()
irish_spread said:sorry nisus posted on top of you. Great minds think alike![]()
madmonk said:tile adhesive
irish_spread said:on the red meself, if only i knew how to post pics........ ;D ;D ;D ;D ;D ;D
NO KIRK NO, I DONT WANNA KNOW HOW ;D
its just i do quite a bit of tiling aswell as plastering so i normally use whats left in the tub i dont go out of my way to get itNisus said:madmonk said:tile adhesive
What do you put tiles on with then Cove adhesive?? ;D
Nisus said:jord218 said:I use artex to put it up, as soon as the plaster is set. never have any probs.![]()
Never tried it with artex, but it would stay workable all day so could bang loads up i suppose.
Do you tack a few nails here & there till it's set when using the artex??
i use b and q own make coving glue powder form it is great ;Djord218 said:I use artex to put it up, as soon as the plaster is set. never have any probs.![]()
plasterjfe said:artex too soft any damp or leaks and the whole lot is down. i cove onto new plaster when dried out no pva using joint filler its stays workable for ages but its a setting product not air drying when its set job is solid
sprayit said:anyone tried the b&q lightweight coving. its fantastic and costs the same as normal and comes in 3.6m lengths
jord218 said:plasterjfe said:artex too soft any damp or leaks and the whole lot is down. i cove onto new plaster when dried out no pva using joint filler its stays workable for ages but its a setting product not air drying when its set job is solid
Artex will work and alot of people use it but as its only an air drying it will go soft if any moisture ggets on it but then i suppose if there is a leak you would have to rip it down anyway
I done loads on price a few years back and the joint filler was the prefered method thats all
Each to their own mate. Ive just never had any problems using artex, but I do have some joint filler left over so will give it a go ;D
plasterjfe said:jord218 said:plasterjfe said:artex too soft any damp or leaks and the whole lot is down. i cove onto new plaster when dried out no pva using joint filler its stays workable for ages but its a setting product not air drying when its set job is solid
