Corner trowel twicher tips
ChrispyUK
Hi all, got some small cupboards to skim and thought it might be a good opportunity to practise using corner trowel. Usually do opposites but thought on this it doesn't matter quite as much if I don't get it quite perfect. Just skimming onto board etc. Cheers guys.
I dont use a corner trowel till the second coat has firmed up and I do two passes on each corner... the first pass one blade on the wall the next pass with the other blade on the other wall... also a nip of gear on the tip helps :D
I do it when the corner is firming up nice :D
It all matters lol well it doesn't if you don't get paid
You know what I mean mate...all my work is done to a very good standard, but as I'm multi trade, I'm not plastering everyday...so play it safe when I do. Just trying to get better mate...
Thanks Danny...that's helpful mate. Just thought it might be a good place to try it out. :)
My method is to lay on the first coat nicely, and when it has pulled in a good bit, run my corner trowel, any lines left by the wings will be covered with the next coat. After 2nd coat has been flattened nicely and pulled in I run them again, and then maybe once more before final trowel (often I don't though).
If it's a hobbly old reskim, I sometimes sponge the internals before using the twitch.
Cheers Dropsalot...appreciated mate :)
Never twitch too soon else you can push a horrible little dip in the corner, only use mine on second pass . If set has picked up a bit put a bit of fat on the tip of your twitcher before running down. I prefer the wings bent in a touch . Finishing a wet angle is like making love to a woman; use your tool too soon and you can spoil the finish and have to use your finger to tidy up. [emoji106]
I hate corner trowels but I think I don't know how to use them. Literally just do corners by using trowel both ways on first couple passes then finish by pulling trowel away from corner (without knuckles in plaster), when finishing up run my taping spatula either side to sharpen corners followed by a brush. Perfection ooohhhh and not a corner trowel in sight :)
Never twitch too soon. :D Gotcha mate...thanks.
See...I'm helping you out too mate with with my post ;) cheers Natwasere
I Dont use them I can do very neat and tidy internals without. I alter how I grip the trowel so I don't leave knuckle marks everywhere
I need to know how you do that Greg ,cos I'm fu cked if i know ,and I've been plastering 35 years , not doubting you btw
I just grip the handle using my fingertips only if that makes sense. Will ťry and take some pics monday at work to show you what I mean mate (y)
I have done it the way @Marshy has before when I have forgotten my twitcher but its hard work... well it was for me when I am use to using a twitcher :D
Added a photo of my twitch - wings trimmed - lessens the digging in as mentioned - MT page had a lot of feedback on the twitcher & how we have adapted them , they where asking for testers of a new corner tool, so I am assuming they may of designed one with the wings trimmed , time will tell -
Jesus Phil get your tools cleaned ffs :rayos:
