Help! Need advice. Had rendering about 1.5 years ago. House is a wimpy fines (concrete structure)
Rendering is fine except the small porch on the front, outer wall originally had thin tiles with a cavity wall. Inside is a small downstairs toilet. Above is a tiled roof which attaches to the house. Inside over the last 6 months in the far top corner (wall which was rendered outside) the plaster has started to flake. (No pipes in this area and roof looks fine)
Thought this might be condensation as the rooms cold anyway however we’ve not had any issues with the plaster before this. I’m thinking it could be to do with the rendering as it’s soaking this morning.
Have no idea when it comes to plastering but now thinking there should be a cavity in the wall? The builder just replaced the tiled wall with a cement mix. Want to try and understand if this is the cause before I call them to get them back to look at it. Thanks in advance.
