Collated screwgun
I’ve got the dewalt with 5amp batteries and I can definitely recommend it. It’s handy because you can have it collated or single screw with different depth settings.
Yss
can you use the collated Hilti on its own say if you wanted to screw 65mm on an over board?
What’s the weight like?
Yes it comes with an additional depth attachment for loose screws . The corded version is lighter than the cordless but it’s still ok . Power is just as good too
Take the battery out , add wire it to so it can be put in your pocket
Hilti all day. Try the SD-M2. It’s on par with the SD57 and the strips are more compact so you can get more in your pouch.
  • Collated screwgun
