Coat thicknesses and mixes
scottlucy
Hi I am hoping someone can help with the following:
the coat thicknesses for each coat and mixes for going over rib lath.
Thanks in advance
Thanks in advance
Make sure you fill the cavity of the rib lath and depending on material you use , you might get away with 5 to 8 mm with bonding/hardwall,sand and cement more like 10 to 12 mm,hope that helps
