Cleaning water inlet on the Ritmo L
Rigsby
TPF Special Forces
Took the water inlet pipe off the Ritmo to clean the inlet and found a white plastic thing with a little hole in it?
so this reminded me of a vid for the power oat which showed the lower cap having a pin on it and used to clean this inlet hole. The vid showed the plastic piece being prized out then the hole being cleaned with the pin off the other cap. But getting this piece of plastic out? Tight as ought! Gave up thought it would snap first.
So, anyone with an Ritmo L how do you clean the water inlet?
Take the rubber geka seal out first. Take the mixing shaft out. Put your hand in the rubber mixing zone and push it out. like looking for a G spot
Tried shifting it on my Ritmo M and it wont budge. Does it matter much if the hole is clear anyways?
The bottom is for skim etc which needs cleaning with the geka pin.
The top plastic we just removed and threw away.
make sure the geka has been taken out. if its too tight you could try screwing a oversize screw in the hole then pull it with a pliers
