casting plaster
S a plastering
whats best for running in situ 4m length will just casting plaster do the whole process cheers trying to learn as much as i can through the forum just fro another string to my bow feel as its a pretty good market for repairs
i use multi. mix it up stiff run yer nould thru buillding it up while the multi stiffins either mix or wettin more keep building untill looks good leave then run thru with a splash of water leave 2 set then same with the mitres.
