Guess all pro.s have a lie in on a sat lolRest being tiled
Is it so that you can get a draw after doing the easy stuff and then run away never to be seen again?Skimming plaster board first before rest . Why
GeniusIs it so that you can get a draw after doing the easy stuff and then run away never to be seen again?
If so, good plan IMO.
No they weren't. Float the walls, skim the ceilings and skim the walls was the accepted order of works.In the days of float and set all boarding i.e ceilings and partitions were tied into block work and skimmed before floating was done . But what the foook is going on there ?????????????
Not how we used to do it Andy all boarding was tied into block work with dute scrim .No they weren't. Float the walls, skim the ceilings and skim the walls was the accepted order of works.
To be fair i would do it that way now as don't use hessian any more . All internal angles use the 100mm fiber tape.No they weren't. Float the walls, skim the ceilings and skim the walls was the accepted order of works.
I've never heard of or seen that before. It was explained to me that you floated the wall before skimming the ceilings so that there wasn't any chance of hitting the finished ceiling with a featheredge or the need to wash the sand and cement off the ceilings.Not how we used to do it Andy all boarding was tied into block work with dute scrim .
Yeah we use the wide scrim for internals, I don't think many do?To be fair i would do it that way now as don't use hessian any more . All internal angles use the 100mm fiber tape.
I can see your point and sand and cement would stain if not washed off, but all we did was wipe it off using a flat brush when floated and before rubbing up. Different strokes.....I've never heard of or seen that before. It was explained to me that you floated the wall before skimming the ceilings so that there wasn't any chance of hitting the finished ceiling with a featheredge or the need to wash the sand and cement off the ceilings.
Morning mate,hope u are goodSkimming plaster board first before rest . Why
Yeah it's one of the things I like about this place, hearing how other decent spreads do things. Just takes a while to work out who to listen to. Ok about 5 secondsI can see your point and sand and cement would stain if not washed off, but all we did was wipe it off using a flat brush when floated and before rubbing up. Different strokes.....
Oh no here we goMorning mate,hope u are good
Three seconds and counting.Oh no here we go
Now I’m not sure what do do first - set the ceiling or float the wall - I was having a happy Saturday before you two started confusing me.....@ beader/@essexandy!
Go to pub, problem solved.View attachment 33023
Don’t you start!Gonna need some bigger scrim lol
Now your just the right height to lick his balls.Bead out, float walls, skim ceiling, skim walls, standard practice, the only time I skim ceiling first is if the walls are being finished in s/c like in garages or out houses . That's how my daddy showed me when I was about knee high!
A safe room for a wire.I give another clue that should give it awayView attachment 33019
Except if the walls are rubbed smooth so as Not to stain them doing ceiling eg garages but bang on otherwise as the floating dirtys ceiling anglesNo they weren't. Float the walls, skim the ceilings and skim the walls was the accepted order of works.
Why John why.Skimming plaster board first before rest . Why
Don't want to tell you lol.Why John why.
Hmmm lights on to the coving must be some fancy stuff or an led strip going around the walls?Don't want to tell you lol.
He.s putting a trough there with lights shining on to coving.
So @essexandy your kinds right I.m getting paid before he turns them on lol
