Bought 1m serrated straight edge today
gooner59
With other stuff from Rafina ,i was planning on rendering on to Styrofoam then ruling -of with the said straight edge ,then applying the cloth-mesh then a second coat over to embed the mesh !! is this right please ??......
Hi Mate,
Standard procedure (dependent on spec of manufacturer) Apply Base-coat onto EPS, rule with 12mm Notched Trowel (this will give you a 6mm base-coat) lay mesh on-top and the flatten the base coat. You can put a second coat over the top, Always ensure the Mesh is kept in the outer 3rd of the Base-coat
Any probs mate, please give me a call and I can talk it through with you
Ryan
Thanks Ryan .
I think i have a v-large 12mm notched Trowel that would suit this job perfectly ........ so what do you modified render guys use the serrated straight edge for ?
Thanks Ryan .
edge is for mono
the spats and trowels for adhesive coat are depth and width measured so as to leave the correct thin coat coverage
