Blocked up doorway
Craig9
Hi all,
I’m blocking up the side of my Internal-doorway in concrete block, I’ll hit off the render around the edge of the existing to carry it over to prevent a joint using Scrim, just wondered what’s the best way to get to a finish coat?
at the moment I’m going to use diluted SBR to prime the wall before I start, give it a good 15mm of render(Holm and cement with sbr in it) then skim tomorrow?
Is this a way I can do it or should I be doing anything different? As I said it’s inside so no damp issues.
Steve Brown
I would of just timber framed it, insulated, plasterboard then skimmed whole wall.
If you carry on on the route you’re doing sort that blockwork out by putting a stagger in it.
The Hobo
Hi all,
I wouldn't skim render the next day when skim sets it will pull face off it
Stevieo
Royal Spin Doctor
Hi all,
Your f**k**g house will fall down if you keep laying the blocks with no key.
Monkey Boy
Probably what Warner’s said.
What you gonna do window side?
Looks like a window in pic? You said it’s a door?
I don’t know, it’s your own place (I hope) and your own plan and you will make it work for you and be happy with it probably
Danny
Administrator
Hi all,
I blocked up a doorway at home but I staggered the joins... it has never cracked and those wall starters are great :D I used them to support a falling down garage wall 2 years ago and the wall has not moved at since :D
Craig9
that bit behind is a window but on the right is the door all in one, but as my conservatory is ancient I need to keep that all in until I change it, when I do I’ll timber frame the back of that block so all I have is a big opening going into the conservatory
tapit
3 /4 days should do it /an easy test run thumb nail down it if it digs in to soft if it leaves a kind of silver mark hard enough
@The Hobo , can you do the same trick with a screwdriver as I have just got my nails into good condition during lockdown. Always file in one direction and use a fine grade of nail file is my tip.
