S a plastering
What's your methods ideas for boarding this hallway ceiling think it's going to be a head scratcher?
Shine a torch from inside the celing and trace the shadow. Your welcome.As a non-plasterer, could you lay the boards out face down on the floor and transfer the curve that way?
Do one wall at a time and lift/screw them into place as you go.
Was thinking summat on them lines cheersTake measurements from the wall to the curve at various points and transfer them to the board then draw it in free hand?
Would you use a router mateOversail boards, guided straight cutter router on perfect finish
I'd cheat....Would you use a router mate
Yes, piss easy, neat cut. Or you can scribe it if you don't want router overheadWould you use a router mate
What's the ceiling height to it?
And what are you fixing too
Might just be me but I can't see what your fixing to on the ceiling
Top hats mateWhat's the ceiling height to it?
One of those days pal didn't even see the post underneathTop hats mate
All that staircase cost £125k
Hold the board up pencil line over the top then deduct the width off the timber, use a rip of mdf to give you the new inner line. I’ve used upvc trim before to
Correct answer!
Everyone elses answers are foookin stupid!!!
I thought it was a trick question !!
You know like when you go for a piss in the middle of the night in the dark and your desperate not to splash the floor....
Sneak off to work early then the phone rings around 7 ....
" Why the fuuck have you pissed all over the toilet floor" ??
Who me ??...must of been the kids !!!
Then you realise you have 3 daughters![]()
Joiner in. f**k f**k**g about with that pish.. Might be a dumb question but what is a top hat? I thought it was something a magician wore to make him look like a magician or a knob...
Cheers mateMetal frame work
So is this strange metal top hat put up by a magician? I'm getting so confused.Metal frame work
I assume soSo is this strange metal top hat put up by a magician? I'm getting so confused.
Appreciate it mate. Never heard it being called that beforeNo it's the metal studding that's got 2 external flaps on! Ceiling track in Leymans terms
