Best Method On A Wall Like This?
beddy
i doubt its growing through it mate, just on it, jet wash and scrape it then render it
church
you need to dig the dirt out of the back and get a liner in or the hand grenade method .
pwi
unless you put a membrane behind the wall as church said theres no point doing the job as you will be back a year later repairing .
theblones
if that is a problem, fix a membrane to it with batterns and fix a calcium board to that.
big expense then.
wash it render it and off we go
oasis
has a nice long curve on it to so boards would be fun ha.. yea my other spread looked at the job i dint ask about the liner but its about 600 high by 20 meters long so a bi to do for a wall!
wiganlad
once its been cleaned paint liquid membrane on the front drill and plug eml. fill the holes with liquid membrane as you put the plugs in. dun this for mi mams neighbour 5 years ago . no probs as yet
oasis
any more info on a liquid membrane?
oasis
ah nice 1 i may need 2 order some asap any local dealer or online company's selling this here?
del
just find out where the nearest sika dealer is, there has to be a few in the uk, sure you will track it down somewhere mate, or someone on here might know.
oasis
basically get off ya ass and sort it ya self now! lol got ya
del
essexandy
The Lake Governor
What do you mean other spread, don't you mean the spread? ;)
C
cwlar33
Guest
dig a spit wide behind the wall all the way down put a 500g liner all the way along fill with pea shingle half way up and fill the rest with dirt. drill weep hole every 4 ft and insert weep pipes just longer than the thickness of the wall so it reaches the gravel, scrape, wash and render the front. Hand grenade sounds like a cheaper and quicker method though !
