D
Deleted member 40920
Guest
Why are some brands of beads about 75-80 degrees rather than 90? Pain in the arse
Bg ones aren’t
Them minimesh beads are utter shiteDrywall minimesh can be pushed in to those angles.
I'd use them if they weren't so expensive , and they have an issue with their shape , one fold is bumped outwards , still use them for archesThem minimesh beads are utter shite
Arches!I'd use them if they weren't so expensive , and they have an issue with their shape , one fold is bumped outwards , still use them for arches
Yup! Used them today because wickes didn’t have any solid. Putting them on a lintel situation sucks. Just know they’re going to show through in places.Them minimesh beads are utter shite
I posted a thread about them a few months back mate , same reason as the op says , it’s like every other bead available is the wrong angle on purposeShes here BG snake!!!!
I would like to know why, why for the love of Thor, if they insist on sticking barcodes on them why can’t they go on the very end of the bead where it’s more likely to get chopped off!!!
So f**k**g annoying! I run a lighter over them and then they just peel off but still!Or even the back of the bead!!!!!
Ah chris hemsworth fan aye? Does ones beloved know?I would like to know why, why for the love of Thor, if they insist on sticking barcodes on them why can’t they go on the very end of the bead where it’s more likely to get chopped off!!!
I’d switch Si out for him in a heartbeat!!Ah chris hemsworth fan aye? Does ones beloved know?
i just stick a piece of tape over the barcode.I would like to know why, why for the love of Thor, if they insist on sticking barcodes on them why can’t they go on the very end of the bead where it’s more likely to get chopped off!!!
Because joiners cant put up a 45degree corner on studwork.Why are some brands of beads about 75-80 degrees rather than 90? Pain in the arse
So is multi finish to people on here! Some can use products some can't .Them minimesh beads are utter shite
OuchSo is multi finish to people on here! Some can use products some can't .
Pmsl!Ouch
Never seen a bg one or stockist in my lifeBg ones aren’t
I understand now, I forgot about your ancestryI’d switch Si out for him in a heartbeat!!
But no that’s not my reasoning, I just like mixing it up! May as well lean on the lineage
Me neither till I seen those ones in travis a guy who does all the new build sites in my town ordered them in because the plasterers were sick of all the other beads availableNever seen a bg one or stockist in my life
What for skimming?I use the catnic 6mm coat ones for bedding on.... They are more rigid than any other bead ...
Yes pal.What for skimming?
Crikey I'm always moaning about normal beads allowing too much thickness.Yes pal.
I think their claim of 6mm is abit generous but they defo thicker than the norm...... But love them as alot of corners i bed onto are all over the place so give you scope to build out and still cover the wings.... I staple mini mesh for board.....Crikey I'm always moaning about normal beads allowing too much thickness.
Actually that's what I noticed about the BG beads, they allowed a nice thin (2mm) coat.
