oasis New Member Nov 19, 2008 #1 why do the beeds some times stain trew the plaster? iv used load of diffrent makes aswsell..
church Well-Known Member Nov 20, 2008 #2 Its the cutting oil on the beads which comes from when they are manufactured its not a problem.
C christ Private Member Nov 20, 2008 #4 seal the plaster with emulsion first..........then use oil based undercoat around the corner to prevent the stain come through
oasis New Member Nov 20, 2008 #5 yea i no bout that..problem is soon as u tell the customer that they tit
C christ Private Member Nov 20, 2008 #6 i know what you mean....... the other day a customer started panicing because the tip of the bead was visible :
