beading
naz
im just curious as to what different materials u guys use for sticking ur beads up with, i use sm700
internally i use mf100...
externally i nail em on into a red plug with a 40mm galvo..
specially bellcast..
Warrior where do you get your dripping from? The stuff I get is OK for upright beads but won't hold the head beads.
staple skim beads or use a bit of multi if its reskim, and externals dab them with whatever material ill be using
I used to use my pulsa gun ,but the beads weve had lately are crap so the gun just busts the webbing so i bed them on with hp12 now
ha ha just read this after posting on the othjer thread about shot fixings ::)
edit: just thought..theres different power shot 'caps' isnt there? black ones go into rsj's! red for brick and yellow for softer stuff?
Home made lad , it's the stuff with the thick black jelly at the bottom (and that's spunky's que)
Basically i stick them with backing coats like s+c and hp12 but use nail plugs and screws for bellcasts on outsides , inside, stick with multi on re -sprays sometimes gripfill or pink grip , nails on p/b, render beads nails or p/b adhesive sometimes multi on low suction blocks, the bloke who taught me said sticking beads was for crap plasterers who couldnt do the job. :o
Years ago during an NHBC inspection the bloke said he really liked the way I dry fixed all my upright beads but would prefer it if I didn't stick the head beads onto the catnic lintels, I just said "you show me some *ucking way to nail them up and I'll do it", I don't think he was used to being spoken to like this and just went away never to be seen again.
steel catnics outside face? never seen that before? internally on the closed back ones for solid 9 garage door posts...? closed backs for cavity walls when theyre on durox block under wallplate but thats d+d normally?
while since ive been on a site though... :-[
edit...
stainless self drillers like tek screws... :D
ill get me coat... :-X
Sorry Chris I wasn't very clear, I meant internal head beads.
internally staples or stick em externally....................errrr........................errrrrr.....dabbing...........err adhesive :-[
i cant nail angle beads externally
