Bauwer thermal plaster
Oxford
Hi every one, I am looking some advice regarding using Bauwer plaster on the external walls of my property to help improve the thermal value. The property was built in the early 1950s with solid brick work and floated in s&c! Which makes very cold walls!!! I am in two minds to take the walls back to brick and finish with a 40mm Bauwer plasterer, or to baton and screw 50mm insulated boards yo the walls. Do you think Bauwer will be a good option as I have never come across it before.
Any advice will be really appreciated.
I've used it and you can put some serious thickness on in one coat. Final skim coat must go onto a damp surface... spray well.
