Baumit lime render
User___removed
I will be spraying this week through the ritmo l weather permitting.topping it with there 1.5mm finish coat.
Anyone used baumit 39 universal before?
Cheers
So I sprayed this today through the ritmo.
Straight onto stonework at 15mm with mesh.a tight coat over the top then scratched ready for float coat
Sprayed lovely.so much easier than hand balling lime render mixed in a mixer.
Spoke to the baumit guys and this gear needs less babysitting than traditional lime render.due to me spraying it also there's no need to damp down the scratch coat either before float coat.
It's only a small job this one but only took 3 hours to spray and mesh 50m2.
On a large job you could really cover some m2 compared to hand balling traditional lime render which I think is horrible to use
