Awkward t**t
Alan b
What do you lot recommend for beading these? It’s simple enough with stair wells I just use thin coat beads and build it out a bit to humour the angle but on these big dormas the bead not fitting over because of it not being 90 degrees is a problem where it meets the vertical edges . Stop beads along the tops seam like the only answer to me , your thoughts would be appreciated
raytheplasterer
you could do a stop bead on each edge, like making a bespoke angle bead, would add more strength.
depends on how posh the customer is.
Stevieo
Royal Spin Doctor
can be useful on occasion, those 3 mm stop beads can go a bit wavy
you wouldn't do it on a building site.
Yes he would.
He's a pikey who wears size six shoes with built up heels because he's 5ft 2 and he wears a pork pie hat and he spits on the floor when he's talking to customers.
He does plastering nowadays because his fairground ride collapsed due to poor maintenance.
He's capable of anything
Spitandpolish
Yes he would.
No he wouldn't.
jamesthefirst
Flexi bead on a roll are good or the BG aqua bead, i think the Newcastle supporter ex army used to post up a special metal bead for these.
