usually keep a tub on the van. i would say unless the artex is really flaky/chalky and looks like it wants to fall off on it own accord, you should be ok with just WBA. really comes in handy on a nasty bit of distemper tho!
Dont just pva the ceiling make sure you use BONDING COAT first cos if you just use plaster , when the plaster dries it will shrink and you will proberly still see the shape of the artex . the Bonding Coat gets the ceiling flat again the you put the skim on that . Its best to put the Bonding Coat on then put the plaster on in the same day cos if you let the bonding coat dry you would have to keep uni bonding the ceiling cos their will be too much suction . you can plaster the next day but you would have to be as good as me to be able to do that
