Apprentice question
I seemed to be getting better results when I put my second coat on thin as fuuck, been told to put it on thicker, could that be causing pitting?
Don't put a second thick coat on, will cause tiger stripes and ripples keep your second coat thin
Who told you to mix 2nd coat thicker? Your dad
I went with a gang for a couple days just to get some experience and they mixed it wetter than first but put it on thicker than I did before, so I carried on like that
Ah sorry thought you meant they mixed there 2nd batch thicker..nah mate nice tight 2nd coat,say you put on 1 and half bag gage your 2nd coat should be barely half a bag..get your lines out before you 2nd coat aswell
Yep definitely flatten in your first coat properly then u will find ur second coat will go on tighter a nicer sounds like u could do with working with an older guy show u all his tricks he’s picked up then u can take the best of what he knows and move it in to your own work the best of what I learnt came from a guy like that
I think I'm ok pal
Cheers mate I’ll try a nice tight 2nd coat again
Cheers mate I’ll try get my first coat near perfect then a tight 2nd
After flattening in with a spat when wet does this look too early for the next trowel?
Put all the gimmick trowels and soats away.
Use 1 13 inch maximum trowel start to finish.
If you try to trowel up your work and your putting lines in and not taking them out its to early thats it. Simplexas that pal
Will do cheers mate
Completing my nvq soon so thinking of going elsewhere to get more experience, anyone know of good companies round Shropshire/ north Wales border
