They brick work is shot to fuk . they are meant to do a dubbing out coat.but getting hold of the them is a nightmare . probably just use ocr n Base n mesh itIt'll most likely be a thin coat system. Just treat it the same as any other. It's quite good stuff. Not used it for a long time but I doubt it's changed much.
Just be wary OCR won't take high suction with wanky brickworkThey brick work is shot to fuk . they are meant to do a dubbing out coat.but getting hold of the them is a nightmare . probably just use ocr n Base n mesh it
We have got a gable to do in this . never used it before done various similar systems but this is a newonderful one on me ??
M R is right but his name was Maximilian RenderbagWe used to do loads of council regeneration work in alumasc when i was younger circa 2004-5 before k-rend started getting so popular. The stuff your mentioning sounds like MR Dubbing, at least thats what it used to be called. Felt alot like a heavier hardwall but built out well which is why it was spec'd for going over existing dash or bad brickwork.
Out of interest does anyone remember MR scrim adhesiveabsolutely hated that gear. Impossible to mix stiff used to drip off your hawk before you'd get back to the wall!
Also, random bit of info. MR apparently standa for Mark Roberts? The bloke who first started making bagged renders? Can anyone confirm that or shoot it down to save me looking at google??
