Alternative to a belle mixer
Olican
I've been doing this for a few years now so thought I'd share it for anyone that doesn't think a good whisk could take it.
On smaller renders I find using a large tub and whisk easier than a belle.
I find it much quicker as I can mix up the equivalent of 4 or 5 belle mixers in one go and has more consistency as it's all same batch.
Plus I can gauge my sand out before hand so it's ready to go. Twenty level buckets of sand then just add 4 lime 4 cement . 20 minutes later you've got enough for about 25m
Also find when topping its lovely to rule and dries really evenly..
being doing that for years for internal s+c or whatever but outside or bigger jobs requiring a ton or more id get the belle out just cos its quicker and easier to stand it behind the van on a tarp and tip into a barrow..
someone once said something about a whisk whipping too much air into the mix but ive never noticed a problem?
I've often wondered that, was going to ask @Rigsby if too much air is a problem.
You get 28 buckets in that tub??:sorprendido3:
The air causes fanny farts ?
using a belle cement mixer is homogenous mixing, using a whist adds air to the mix so the theory being if your using a whist your adding a lot more air to the mix, and the materials not binding together enough.
How negative is it in reality ,? Has it ever been tested , have there been fails ? Ie debonding , I can’t see it myself as a negative
I’d like to see it , do you mix 4/1 then add another 4 or throw the lot in , anyone else I’d be mmm but you’re a decent lad
You had me doubting myself for a minute there John, no I've done lots of mixing with that tub and it feels like second nature. 16 buckets for scratching 20 for topping. Like a skim tub it's developing tide marks
How many walls have turned to dust ??!
I remember when the drill mixers were first used for plaster /skim , the old boys said it was over heating and causing fast setting , back in the late 80s
I remember my dad with a labourer scratching the downstairs of a house , I turned up a week later to topcoat and.saw immedeatly it was shot knocking of some high points , had to rub it all off clean with a stiff brush
Was working away in Wales and the local labourer couldn't understand what was the problem , I thought it had been frosted but didn't make sense being indoors , I realized the problem when he mixed up , over Feb and left it running to have a fag and make a brew lol
You wouldn't want to stand under a doorway with a solid coat on top
Can't see a problem with using a whisk , its excessive overmixig causing too many bubbles , render cures like a biscuit
When we did a lot of sika work in the early 2000s, on the spec and even on the cans it said to use plasterer whisk/forced action mixer and to avoid using a tumble mixer (belle) excuse of the air introduced into the mix.
Always found a nicer mix with the forced action or mixer drill.
More reliable surely. Whisk/forced action.
You're forcing the mix into itself.
Way better blending of the ingredients.
I'll find the spec.
From sika website
For sika 1 system. (Waterproofing)
  • Alternative to a belle mixer
The problem is , whether it’s a mixer or a whisk, people are impatient, they will put more feb/waterproofer in to Knock it up to a spreadable consistency , rather than a nominal amount and take time to mix it , add to the fact most blokes use the plastic bag cement with added plasticiser rather than the paper bag cement , these two factors added together = less water used = a weak mix
This labourer was supposed to be a bit of a brickie , say no more lol
Back in the day when skim was mixed with a bike cog, we would use a whisk on a drill for the last little bit, sometimes, for the last bit we’d give it a longer whisk as this tended to set it up a bit quicker.
I liked to use a whisk for sand cement render when damp proofing for all the reasons mentioned.........and if I’m correct goldblatt used to make a serrated darby for knocking air out of render coats?
