Advice on k rend roughcast
Hadley
Hi looking for some advice on expansion bead placement on roughcast k rend. I have used Krend b4 but never rough cast with it. Any advice would be great
PlasterCraftDundee
If its a new build the brickys should have an expansion joint in the block work, its either every 3 or 5 metres can never rememeber, if you are going over an older property you can really just split panels up however you want. Well thats what I do with traditional sand and cement roughcasting I assume k rend would be no different
Jimbob9
If there's no expansion joint in the background then there's no point in putting onein unless you absolutely need something to work to and in that case put it wherever you want.
K Rend
Forum Sponsor
Hi Hadley, if you contact our K Rend's Technical Sales Consultants they will be able to offer you advice. You can contact them on 028 2826 0766.
