Advice needed
AJG22
Hi,
I am new to plastering and had a lot of damage to the kitchen wall which I filled with standard filler. I bought some PVA and Finishing plaster to do the wall but do you guy think this would be enough?
Alan
If you need to ask, then don't do the plastering yourself, you will end up needing more filler.
As spread95 said, fine coat and sand.
If you are still unsure, one coat of paint on the wall will give you the answer
Hi,
Alan
Scrape any high spots off the filler and get it as flat as possible then give it a thicker than usual coat of skim if need be an it will be fine. Assuming you're competent
