Hi,@John j
What’s the question mate??
If your happy yes.Hi,
I am new to plastering and had a lot of damage to the kitchen wall which I filled with standard filler. I bought some PVA and Finishing plaster to do the wall but do you guy think this would be enough?
Alan
Would you do something different? If I do what I suggested will the wall be smooth and even despite the filler? ThanksIf your happy yes.
If it needs it I would just put a fine coat of filler on that and sand it smoothWould you do something different? If I do what I suggested will the wall be smooth and even despite the filler? Thanks
Hong Kong Phooey stylePut a yukka plant in that corner!
Scrape any high spots off the filler and get it as flat as possible then give it a thicker than usual coat of skim if need be an it will be fine. Assuming you're competentHi,
Alan
