hi its just a general question,is it worth adding some pva to a multi finish mix just prior to mixing to aid skimming time,also do you think it will give a good finish![]()
whats freeflo???how to's would be good.
Cement is better trust me. It keeps houses together ffs about a handful per bag of multi
When I started out many moons, ago before we got all uptight about PVA mixes. The old spread that taught me always used the left over watered down PVA in the 1st coat when reskimming or going over anything that we had put PVA on. I asked him why and he said that doing this meant that you had PVA sticking to PVA and we never had any problems and it went off fine.
on the internet you can get de-ionised water in 45gl drums thats what u need, i can't explain it it's a science thing but it works.
other than that the best thing to do is carbonate your water in a soda stream prior to mixing but make sure you use it while it still has its fizz
[/quote]to the max, and the added bonus is there is always a tasty beverage to hand when u work a sweat up troweling up that extra 20-30m you were able to get on when using this method quote=artisan998;645769]you mean "get busy with the fizzy"...............:rps_thumbup:
