adding lime to multifinish
You shouldnt be adding owt to plaster except clean water all this fannying around putting stuff in it to extent setting times etc is a joke imo, waste of time
i have done it a few times and it makes the stuff fukin lovely, like plastering with whipped cream!
beware! put to much in and it fuks the painters up!!!!
you have been warned
its fukin KIRK
KIRK KIRK KIRK KIRK KIRK KIRK KIRK KIRK KIRK KIRK KIRK KIRK KIRK KIRK KIRK KIRK KIRK KIRK KIRK
IT WAS RAINING THIS MORNING MUKA
its not raining here kurt, i'm sat in waiting for a delivery of venetian plaster. great laugh.
ive got to learn myself first! ive got the myke wye dvd aswell, it looks straight forward enough. i'll put some pictures up soon.
ok i need you to take a pick of each step in the process and also explanations to accompany each photo thanx
p.s. when are you starting? today or tomorrow? ;D
i've started now. i've got loads of 2x2ft mdf practice boards. just don the first coat on a couple, i've got to let it dry for a couple of hours then give it a very light sand. i'm going to take a pic of each process. hopefully it'll look the muts nuts. render systems has got some videos on youtube how to do it.
Make sure you get it on real thin, or it tends to peel, especially if you have tapped off any areas, when you peel the tape away.
i've only give it a first coat so far, the lime wall finish stuff. got white plaster and pigments to mix it myself. any tips on a nice colour to try kebab?
Depends on the light in the room , i did a black n white ceiling in a office, it looked the muts nuts.Anything well pollished tends to have a good effect.Just rember to measure your mixes,even if your practising, cos if you really like the colour you will probablly never match it exact again.
