Acrylic/silicone finish
User___removed
I have a job to fit ewi on some elevations on a property.
The client wants the finish to match the existing finish which is sand/cement.hes not keen on a 1.5mm grade.can anyone recommend which finish would be best suited
Cheers
You can finish the base flat if you use the right product then use their acrylic paint.
Get a sample from Parex they do 0.5mm or similar see if he likes that.
Marmorit would be a good system for flat finish with their autol paint
That base what have to be mega flat and tidy with a 0.5 I imagine john?
Done plenty of 1.5 so know how the base coat needs to be finish to receive
