Acoustic plaster?
Anorth
Anyone used acoustic plaster?whats it like to use?isit something you could give it a go n hope for the best or would it be better gettin someone that uses it often to come and do it? Many thanks
Spoke to my mate earlier,hes fitting some type of acoustic boards but said the person hes doing it for wants acoustic plaster put over it.never heard of it meself i thought the boards were the finish.
There is no acoustic finishing plaster being thin coat the sound proofing properties are none existent.
As said a 6mm coat of soundcoat or 12mm of sand and cement (not scratched) to blockwork then stick with soundbloc plasterboard.
Or stand an insulated stud wall up in front of the existing wall.
Acoustic plaster if they still make it has been around for many years, it was used for walls in squash courts i think, theres also xray plaster for hospitals.
@malc
Just had a browse through google.theres a few different types of acoustic plaster, i think most of it has to be supplied fitted and sprayed by the acoustic companys cant find any other products anywhere else.
As said It mainly comes in as part of a whole system boards/membranes and finishes which would be applied as a package by specialist firms.
