1) if i have to board out a non square room and one corner if you can call it that, is about 125 degree angle how do i do it???? i can bud up the boards is with clever filing and then scrim the joint but how do i get that razor sharp look when i plaster???????????
2) if i were to use thin coat stop bead to break up a large area into more managable area's whats the best way to bond it onto the walls and would you be able to see the joining line when its all finished???? i've been told you can use scrim tape for this job and then just peel it off to leave a neat straight edge????? any pro's comments welcome cheers 8)
