D
Deleted member 23452
Guest
The patient is a 1930's semi detached house which has original rough cast render that's past it's best. Loose patches, old repairs, layers of flaky paint etc. There are no large areas as the lower half of the gable wall has a garage linked to next door. The bay window store riser at the front is tiled, and the area below the ground floor window is exposed brick. I'm sure you've all seen many similar properties.
Leaving out EWI and cost considerations, what would you do with the render if it was your own house?
Options I can think of currently are:-
1) Have the lot off and replace it with new rough cast.
2) Replace it with smooth sand/cement/lime render and paint it.
3) Expose the brickwork and point it nicely.
4) Cedar cladding to the first floor and point the brickwork on the ground floor.
5) Something else?
It needs to look smart, not look odd on the age/style of house, and last well.
Not keen on the current silicone/acrylic renders as they seem to go manky looking after ten years or so and need painting anyway which sort of defeats the object as far as I can see?
5) Something else?
