180 sqm rendering required Private House
justincase
Hi all
I'm looking for a rendering gang that can do 180sq metres of colour through render to a house in the Bedford area, either K or Mono depending on price.
100sqm is on the existing building 80sq on new extensions to this building the existing building will be meshed I will take care of that and the new building is constructed from 7n concrete blocks, scaffold is up and this is ready to go.
My client has had a few problems with builders on this project and I have been over seeing its completion.
I can be contacted on 07966 570509 or reply here.
Thanks in advance
Paul
CTPlastering
Sure some one will be along soon in your area , some may want to install mesh them selves rather than by you just as a bit advice , also if anything went wrong and you had installed the mesh ..... The gang will point at you hope this helps !
justincase
I don't have a problem with that,
