weber ocr tips
RJDEAN
how does everyone finish ocr?
at the moment I'm spraying, serrated rule, spat, I bar and sponge.
just struggerling to get on more than 45m2 as we are having to do full mesh.
getting it on between 11 and 12 depending on start but it's just taking ages to go off. any advice?
seems to tear when I bar but if I left it any longer I would be there till 8.
I darbied n rubbed this extension up by 2.30 this time last year using 10mm beads
I'm pretty sure your standard render systems need to be 15mm If going to standards.
So if your just using ocr, mono then it's 15mm
Roughcast 10mm base 5mm for rough cast.
Tyrolean 10-12mm base 2-5mm flick.
Anything over existing can be 10mm
I think thin coat is 10mm base then thin coat top but that's because thin coat is silicone so more weatherproof.
I may be wrong.
I've seen many a jobs with mono/ocr and 10mm beads used and the blocks grinning at you like vince and his selfies [emoji51][emoji51]
