Render stop beads
sammoseley
Hi
Sorry probably a silly question but I’ve got a small area to render, done a few bits before but only with angle beads never needed a stop bead. Need a stop bead to go up the wall for this one (goes from block to brick), now I’m planning on going about 20mm thick 2 coat S&C, but I’ve come unstuck trying to get a 20mm stop bead as they all seem to be bellcast and surely that won’t look right going vertical up the wall.
Only stop beads my merchant or travis has got is about 13mm.
Like I say I’ve made a basic mistake here any advice on what’s normally done much appreciated cheers!
Thanks guys yeah I’ve got stainless ones, seen the screwfix ones but gone for the 13mm stainless stop beads, that’s gotta be what people normally use? Was just worried it would make my coats too thin but say 7mm scratch 6mm top I should be ok? Cheers again
