Question about PFT G4 230v vs 380
Tanel
Im planning to buy one. but im working at heights so in need to know how high these machine can deliver stuff. 230v vs 380v.
if you're thinking about a g4 switchable i would say use 3 phase if u are pumping high. If you are just doing houses and normal stuff the machine will be ok in 230v mode.
Using parex monorex as example in single phase mode you could pump about 20 mts away from the machine ( 10 mts vertical) in 3 phase mode around 50 mts (20 mts vertical)
hope this helps.
Where are you based to
